hubert.chapell Posted July 8, 2013 Posted July 8, 2013 Hello there..I have a Beko washing machine WM6133W.Recently, the motor started to change speed every 3 seconds or so. I thought it was a tacho coil that was broken but I found out that it is a ring attached to rotor shaft (where the tacho is reading the speed of rotor). It seems it is made of plastic (brown colour) and it is cracked in half. As it was attached to rotor I'm just wondering if it's possible to buy it as a spare part. Any suggestions? Photos attached.Thanks. Daniel
Root Admin Whitegoodshelp Posted July 9, 2013 Root Admin Posted July 9, 2013 Sadly, and outrageously, many if not most manufacturers only want to sell a complete motor and no parts are available (other than carbon brushes). Try this link and if you can't find a spare part contact them to see if they can find out if one is available or not - Spare parts Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
hubert.chapell Posted July 9, 2013 Author Posted July 9, 2013 Well, finally I found out that the tacho magnet is machine pressed onto the armature and therefore is only supplied with the motor. Even if it would be available as a spare, honestly it would be very difficult to replace. I've tried to take the whole thing off - without success. Anyway, thanks much for your advice. I really appreciate that. At least I know what to do. Daniel Whitegoodshelp 1
Root Admin Whitegoodshelp Posted July 10, 2013 Root Admin Posted July 10, 2013 It's an example of what I've been complaining about for many years. In an era when we are supposed to be seriously concerned about the environment and how many products are scrapped many years before they should be it's an outrage that these companies get away with it. Tacho magnets cost just a few pounds, and the clip that used to hold them in place cost next to nothing. Instead, most machines with this problem will be scrapped because it's too expensive to buy a complete motor. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
jestrab007 Posted January 3, 2019 Posted January 3, 2019 On 09/07/2013 at 23:07, hubert.chapell said: Well, finally I found out that the tacho magnet is machine pressed onto the armature and therefore is only supplied with the motor. Even if it would be available as a spare, honestly it would be very difficult to replace. I've tried to take the whole thing off - without success. Anyway, thanks much for your advice. I really appreciate that. At least I know what to do. Daniel Hi Everybody, this thread is a bit old, but it helped me identifying the tacho coil very well. I was succesful with the repair finaly, so, maybe it could help somebody else: 1/ Tacho coil is machine pressed on this Beko motor. However, i was able to remove it a) I used a screwdriver placing it at the bottom of the coil (under the coil) from the side (facing the shaft), hammering on the screwdriver gentle and shifted the coil by cca 1mm. Be gentle to avoid the damage of the shaft. b) Then, i shifted the coil by levering using the screwdriver, piece by piece, be patient again 2/ The tacho coil is available in Czech republic for 8euro. 3/ I used some accessories to press the coil on the shaft using hammering. I tried not the hammer on the coil to avoid any damage. I used a screw or the screwdriver extension (see foto) of the same diameter as the inner coil ring, placing it on the inner (gold) coil ring and hammering on that many many times, shifting it piece by piece. It is not easy, but it is possible. I was succesful. Whitegoodshelp 1
