Showing results for tags 'drain pump'.
  1. Hello Andy, Have you heard of these self clean drain pumps on washing machines - I dont know which Hotpoint it was that I have had in the past but I am pretty sure one of the 'features' in its marketing blurb was that it had an auto-clean drain pump (presumably you did not need to empty out the drain filter regularly and that the pump cleaned itself?) Just wondering do you know how that would have worked and wonder why not all washing machines then come these days with self cleaning drain pumps then?
  2. Hi,[/size] I have just replaced the drain pump on my washing machine and I'm suddenly unsure if what I've done is completely safe. I have a Samsung washing machine, model WF7602NAW/XEE, ser no.: X8985ARQ500554D. I've used a new pump - model M224 XP, it's 40 watts and the old pump, model M-47 is 30 watts. Have I used the wrong part? Does the difference in wattage cause a problem? The website I bought the part on said it fit for model WF7602, and I have a WF7602NAW/XEE what do the letters at the end of the model number mean in this case? The old cover for the original pump also doesn't fit the new one, so I put in the new pump without anything covering it. Does this create a fire risk in the event any dust settles on top of it? I've already done one wash cycle without any problems, but I wanted to be sure that this was safe. I really appreciate any advice I can get! Thanks, Alice
