RosieAnna Posted March 15, 2022 Posted March 15, 2022 (edited) I was cleaning out my washing machine - the detergent drawer and the filter, I ran some hot water through the the empty detergent drawer slot to help soften the dried powder. The water ran through the machine out of the slightly loosened filter as I had just placed it back but left it loose to flush the water out. Shortly after there was a water proofing error. After tilting the washing machine to ensure the water didn’t wash back into the machine the error went away, but changed to a “Technical ! fault F169”. I can’t find this error code anywhere in a manual, but the guidance for technical faults is to switch off and on again at the mains. Unfortunately, I don’t know where the mains are as I rent and I’m not sure what the issue is or what I’m supposed to do. If anyone could help I’d appreciate it. All parts (filter and drawer) are back in place and I’ve switched the machine off using the normal power button. Edited March 15, 2022 by RosieAnna Forgot a detail.
Root Admin Whitegoodshelp Posted March 21, 2022 Root Admin Posted March 21, 2022 Hello RosieAnna. It might be that there is a float switch built into the base of your washing machine to detect leaks and some of this water ran into the base of the washing machine. This would also tally with the fault disappearing when you tilted the washing machine. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
RosieAnna Posted March 21, 2022 Author Posted March 21, 2022 Hi Andy, Yes that's what I thought for the water proofing error, which is the error that went away. But then the "Technical ! fault F169" error appeared and that's the error code that I can't find elsewhere. Thank your for replying.
Root Admin Whitegoodshelp Posted March 21, 2022 Root Admin Posted March 21, 2022 The only thing I can suggest is disconnecting the washing machine and taking off the back panel to check that there isn't still any water in the washing machine's base and that the float switch if fitted moves up and down freely, and hasn't stuck. After that there is nothing I could suggest except contacting Miele as I do not have any error code like that myself. RosieAnna 1 Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
