Hi all! I'd be grateful for your help...
A couple of weeks ago, I was using my Indesit WIXE127 (UK) (TEV) which I've had for perhaps 9 years from new without any issues.
Just as the wash was finishing its final spin, it began making a loud, rapid knocking sound and what appeared to be smoke came from the machine! Believing the machine to be knackered, I waited for the smoke to clear and had a poke around.
I started by unscrewing and removing the back; there was nothing obvious. Nothing appeared to have caught fire. What I did find however was the plastic part lying loose on the base of the machine.
As I looked through the door, I could see that the seal had somehow become caught between the drum and whatever surrounds the drum (excuse my lack of technical terminology!) wedging the drum and preventing it from spinning. By removing the seal, the drum came free again.
A few months ago, I did use a mould cleaner on the door and there did appear to be some perishing of the seal around where it became trapped by the drum.
So...
My working hypothesis was this:
The seal had perished possibly due to the mould cleaner and part of it had become wedged by the drum. When the drum attempted to spin, the friction caused the rubber seal to smoke. There were signs of charring on the seal.
I replaced the seal today and gave the machine a go.
It's 90% fine in that it washed fine, the drum span and nothing smoked.
What I did hear however was a knocking sound when the drum is turning anticlockwise. It's absolutely fine when turning clockwise. When turning by hand, the same; no noise clockwise but knocking anti-clockwise.
Given the symtpoms described:
1) What could be the issue? My guess is something to do with a bearing or gear? But this an uneducated guess and any ideas would be appreciated...
2) What is the plastic part I found in the base of the washing machine? I have tried to upload pics but for some reason the forum is saying the files are too large even though they're well undersize... I'd describe it as appearing like a small cotton reel around 40mm in length, one end is slightly flanged. It appers to be made out of plastic/nylon with a hole going right through as if a shaft is desiged to pass through it. It's an off white colour.
3) Could this part lying loose be part of the problem?
Many thanks in advance for any guidance any of you kind people can give...
MW
The part could be from the transit packaging and not needed. What size are the photos?
Thanks or youe response.
I've messed around with the photos and now got them to attach.
Having looked in the back of my machine again today, I found another of these "spindles" meaning I suspect it is something to do with packing.
Have recorded a very brief video which hopeully gives an idea of the sound made when the drum is turned anti-clockwise by hand...
The sound heard is consistent and occurs when the drum hits a particular position when spun.
Thanks once again for any help.
Furthermore...
When turning the drum direct from inside the drum ie. through the open door...I can feel a slight "judder" in the drum as if it moves slightly off its course just as that knocking sound occurs...it's barely noticeable but I can definitely feel it.
 Yes they are definitely transit packaging and can be discarded
Wow that’s the briefest video ever :) Too short to get an idea.  To troubleshoot something like that you need to take off the belt to work out if the noise is caused by the motor, the belt or the drum. Also make sure the plastic drum pulley isn’t loose on the drum shaft.
