Hello everyone,
we recently purchased a bush a1249rlb, however the door is cracked and leaking water, a lot of water. Just wondering if anyone has any knowledge on what doors will fit and if bush use a standard system of dimensions. If so could anyone please kindly post models which will fit the model we have as I’m struggling to find one. Thank you for your time.
Alf
Hello. Is it the door glass itself that is cracked? Or is the water leaking from the bottom of the door? Can you see the part that you need on Ransom Spares?
