Newbie post, got a slight leak. Had washer over and found end point ... But before I reach for screwdriver, does anyone have advice about where this 'might' be originating from/seen it before.  It's not a great deal of water but the staining at least shows me I am not dreaming. Door seal is grubby but seems intact. Model: wmal 621 6kg
Images:
https://drive.google.com/folderview?id=1l0Ihm2JDe_IySR7bXDqgk2Yj7IJT8fNs
Or
https://drive.google.com/file/d/1as8MGu0zX8n76ElR_yrl07St3bDqwTyr/view?usp=drivesdk
Thanks for your experience.
If not clear from image, the concrete is towards the front of nachine. Looking at it, the drip point is central to door, but that might only be the fall point of the leak and mean little. By the way, I did read the sticky post on leaks before adding this!
Leaks can be very difficult to find. As you have mentioned, the point at which water drips is not necessarily the place it is leaking from because water could be running from much higher up. If the marks you have photographed are definitely water leaks then the main suspect is likely to be the door seal where it attaches to the outer drum. But it could be leaking from the outer drum itself, especially as many of them now have 2 halves of the tub sealed together. You could also try examining carefully all of the inside of the door seal. Check to see if there are any small holes anywhere at the sides are at the top or bottom. A door seal can leak from the flange that presses against the door glass, at the point where it attaches to the out of drum, or through a hole or slit in the rubber between the 2.
If you can't see anything it might be necessary to take off the door seal. Once off you should be able to see if there is a watermark running down the front of the drum from the point where the door seal attaches. Whether or not you decide to try taking off the door seal is up to you. It can be relatively straightforward or it can be quite difficult depending on the machine.
