Hi Team,
Hopefully posted in the right forum and first post for now!
I have a Siemens washing machine WM14S794GB / 08 and it continues to run with 1 minute to go on the display.
I have cleaned all pipes, pump filters, etc and cannot find any blockages.
If I run the machine on a quick 15minute (30 degrees) programme, irrespective of spin speed then the cycle completed without any issues at all.
The problem only occurs if I choose a programme other than the quick 15 minute programme... :(
I have checked the forum and have read posts on heater elements, pressure switches but cannot understand how these could be faulty if the 15 minute cycle completes?
Not sure if I an applying the right logic to this but would appreciate any support or guidance as machine came out of extended warranty 5 months ago!
Thanks in advance.
Sticking on the last minute seems to affect a lot of different makes and can be tricky to diagnose. Heating element going open circuit, pressure system faults or blockages or even loading issues are some potential causes.
  • 6 years later...
I had the same exact problem on other siemens model (s 12-44). I have opened the back and found that the on the heating element one wire was disconnected!
reattached it and now thanks G-O-D everything works !!!
