Showing results for tags 'water not filling'.
  1. Hi everyone, My Samsung SW50USP top load washing machine is not filling up. The water supply has enough pressure and I cleaned the filters already. I tried checking the voltage at the water valve solenoid but there is no voltage. Next, I thought the problem might be coming from the pressure switch but when I fill up the machine manually with water, the cycle continue to operate normally so it makes me think that the pressure switch is functional. Unfortunately, I don't have a continuity meter to test the solenoid as advised in the troubleshooting guide, do you think it's worth investigating deeper an issue with both the solenoids even though there isn't any voltage coming to them once the washing cycle is activated? Thanks for the support, Xavier
