Showing results for tags 'turns on'.
My washer drier flashes light when I turn the knob to choose a program but it doesn't go anywhere beyond that. Usually this is the light screen that shows up (see attachment) before changing to the program setup but now it is just stuck here. I tried unplugging it for a couple of hours and it still does the same. This is the model: SIEMENS WM16S792NL WAS/DROOG
I have a Samsung p1253 washing machine all working fine in till it is put on any wash cycle, the machine every so often during the wash will turn itself off without giving a fault code then come back on to the same program but 2 minutes behind from when it went off (goes off 12 minutes comes back on 14 minutes) any ideas how I could fix this problem?
