Hello All,
I have just bought a Logixx7 integrated washing machine as part of a whole new kitchen. It will not spin dry washing at all, I have tried all sorts of combinations pf program and loading from full to just less than 1 kg. Bosch customer service have basically told me it has to have a full load to spin which is laughable as who does a full load every time. So I end up with soaking but clean washing, the engineer said there was no fault when clearly there was.
If anyone has a suggestion as to what I might be able to check, otherwise its going back for an integrated machine that spins.
Thank You
HI this sounds like a pump problem,the machine gos into a spin but comes out wet ? so the pump is not working or its jamed with rubbish.It possible the motor pump could be knackered .
If the problem is out of balanced loads it should only happen occasionally. If it's happening all the time then unless all your loads are extremely unusual it must have a fault or be totally unfit for purpose.
(Related article Washing machine wont spin just one item or very small loads)
