Hi
The touch screen on my Hoover is very unresponsive.
If I'm lucky I can change the temperature of the wash by pressing the screen 20 or 30 times. The spin speed is easier to change but sometimes takes a few presses.
I wonder if this is a known problem and is there a way to make it any
easier to use?
Hello there. Is there anything in the options (bottom right of the screen)? I can only assume with there is no way to adjust sensitivity, which to be honest and be a little surprised at, then it may be a fault on the screen. One thing I would also do though, is to check the instruction book for instructions on how to clean the screen and just make sure it is nice and clean, just in case, though that I have to admit is a long shot.
Thanks, the options is just the three you can see in the photo. I will have a look at the instructions. I've read in online reviews that you have to press quite hard but it shouldn't be this difficult!
Thanks, so that "options" section does not open separate options? That seems very strange, I've never seen the word "options" that didn't mean if you click on it, you can adjust hidden options. If that's the case, it's not a very good design at all.
Also, I've just had a thought. Could it be that you have to press and hold for a few seconds before anything activates? I'm just wondering if they have designed it so that it is not sensitive to quick, potentially accidental presses?
Hygiene + seems fascinating on this machine. It says in the manual "it maintains 60'c throughout the wash" - so when they say 'throughout the wash' do they mean its 60c throughout the wash and including the rinse right to the end of the wash cycle , or do they mean that 60c temperature until it gets to the rinse cycle and the rinse cycle is as normal cold water rinse?
It's a bit misleading. It can't maintain 60 degrees through the entire wash unless it starts the wash at 60 degrees. Presumably it means once reached it maintains the temperature but that wouldn't be accurate as how long is that?
It could be to counter the criticisms I wrote about here
washing machines not delivering right temperatures
there used to be a washing machine out a few years back now with a rinse called 'medic rinse' i think it was (could have been a Haier make) and that I think did rinse in warm or hot water. The thing with that is that if you want to get suds out of clothes you would rinse I think with cold water I would have thought as hot water would just keep the water soapy?
If you did have a washing machine that rinsed in hot water and the clothes came out warm rather than cold (as in cold rinse) and you then put the clothes into a tumble dryer or out on the line then would they actually dry quicker because they started of drying warm instead of cold? - there's a question for you Andy :)
Yes, warm or hot water does create more suds but theoretically that could be more efficient if it draws out the suds. I've heard it claimed that rinsing in warm water is better. It's possible the only reason we don't is the extra cost. I remain unsure.
Regarding the hot clothes drying quicker I'd expect that would be the case. Though I've seen that hot water freezes quicker than cold water. And science apparently can't explain why.
