Hi people,
Had my LG washing machine for a while and has run smoothly until the last few weeks where it is very loud on spin, like very loud. It’s like a grinding noise.
Any ideas / help on sorting the issue out?
Short clip os attached
Thanks in advance
Hello Sar. Unfortunately your video didn't work. I tried to re-upload it but I got a message saying it could not play and could be corrupt. Would you be able to upload it again please?
Meanwhile, can you also tell me is it a direct drive model, with no drive belt or separate motor?
Hmm. No it still won't play. Never see this issue before. I get the error message -
"This attachment is not available. It may have been removed or the person who shared it may not have permission to share it to this location."
Regarding noise, if it is a direct drive could be something to do with that. The only thing you can do really is to disconnect the washing machine from the mains, pull it out, take off the back panel, and have a look round to see if you can see or identify anything that may be loose. Try spinning the drum by hand.
If you can't find anything then an engineer would plug the washing machine in, put it on spin and carefully observe and listen to try and identify where the noise is coming from.
It works ok on my mobile phone though.
Sounds like could be bearings on the drum wearing out @SAR. - try opening door of washing machine and push up and down the top lip of the drum, there should be no movement / play there
