Hi all, hope you can help.
I've moved in with the Mrs and discovered that the washing machine is plugged into the hot tap. I've never heard of a machine where it's not supposed to be plugged into the cold, so I figured I'd check online to make sure, but I can't find any reviews or a user manual on the internet and the Swan helpline isn't open on weekends so I'm a little stuck. Could anyone confirm if it's got its own heating unit and I should switch it to the cold tap?
Thanks in advance!
Hi. Washing machines with only one water valve should be connected to cold water only. They all have heating elements.
