Brian Posted November 27, 2006 Posted November 27, 2006 We have recently purhcased a Bosch Exxcel WVT1260 washer dryer and it works fine other than a tendency to "wander" on the spin cycle. We have had it replaced but the repalcement has the same problem.Is this a common problem with such machines - and other makes? And what can I do about it. It is free standing directly on new floorboards (not laminte and no floor covering as yet). Any help or guidance would be appreciated.
Root Admin Whitegoodshelp Posted November 27, 2006 Root Admin Posted November 27, 2006 The cheaper the washing machine, the less stable it's likely to be on spin. Bosch are relatively cheap, but still a respected make so they shouldn't be too unstable but they won't have the best suspension available. If you've had two and they are both the same then it's unlikely to be a fault on the washing machine. The usual culprits for lots of moving about on spin are failure to remove the transit packing or standing it on laminate or other smooth flooring. Bare floorboards could still be fairly smooth and allow movement although with a properly balanced load there shouldn't be much movement most of the time. You could try standing it on a thin mat or carpet tiles. Make sure you are filling the washing machine well and not under loading it. Also, try not to mix heavy, absorbent items with laundry that is light and doesn't soak up much water, this can cause uneven spinning too. [ Related link -Loading a washing machine: How to avoid out of balanced loads ] Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
jojo1474 Posted April 26, 2007 Posted April 26, 2007 tip dont do a full load of towels in it as they wander more then even my 9 yr old hotpoint does
[email protected] Posted April 27, 2007 Posted April 27, 2007 Is the machine fitted with adjustable legs, has the lock arrangement come loose which will start to loosen even more when the vibration starts.
Root Admin Whitegoodshelp Posted May 24, 2007 Root Admin Posted May 24, 2007 tip dont do a full load of towels in it as they wander more then even my 9 yr old hotpoint does Towels can be difficult, as can sheets. You need to avoid underloading the washing machine too, which can end up being even worse than overloading. Another bad thing is mixing just just one, or a few towels in with much less absorb and and lighter laundry. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
