MiffySnow Posted December 1, 2017 Posted December 1, 2017 My problem is that I cannot open my washing machine door and I believe it is the lock which is at fault not the door's physical mechanism. I need help to override the lock or to know how to break off the interlock without damaging anything else. Key points Machine tripped electrics or electrics tripped causing an error message of all lights flashing. Machine was empty of water. The door lock light remained on, I tried every combination of cycle and the light always remained on. Leaving the machine off for hours does not reset it. I have cleared the drain. I have removed the control board and no visible capacitors blown. I have tried using a string to open the door. I have removed the lid and disconnected the power from the interlock. If I pull the handle the metal hook moves easily, I can feel this when touching the interlock. I have tried bashing the interlock in case this releases it. I have checked the manual for any override codes. Any help gratefully received in forcing the door open or how best to remove the interlock from the inside.
Root Admin Whitegoodshelp Posted December 2, 2017 Root Admin Posted December 2, 2017 Sometimes you have to break off the door lock. I have an article on this issue Washing Machine Door Will Not Open Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
