I have a Samsung  p1253 washing machine all working fine in till it is put on any wash cycle, the machine every so often during the wash will turn itself off without giving a fault code then come back on to the same program  but 2 minutes behind from when it went off (goes off 12 minutes comes back on 14 minutes) any ideas how I could fix this problem?
The first thing I would check is the wall socket and plug to make sure there isn't a dodgy connection. Try wiggling the plug around when it's on to see if the display cuts out.
