Hi guys,
Yesterday our beloved Bauknecht WA 821 (yes..its old…) stopped spinning. I checked the drive belt and it seems to be just fine.
Here’s a short vid of the inside and the problem: https://youtu.be/osZSkDPCbX4
Can anyone tell me what the problem is and how to fix it?
Thank you!
grt,
Wim.
Hello Wim.
It sounds like the washing machine has pumped the water away okay and is doing the distribution section just before the spin. A common cause of it not kicking into a fast spin after draining all the water out is an unbalanced load but if it's quite an old washing machine it may not have out of balance protection.
This particular fault can have many causes, and I've tried to cover them in this article - washing machine won't do the fast spin. To be honest I think it's the kind of fault that is often not appropriate for DIY repair unless you are already an engineer know what you are looking for. It does sound quite noisy and that's before it goes into spin so it could well be that it's just not worth repairing to be frank. However, have a look at my article just in case.
  • 1 month later...
Ahhh i think i have found the answers to my problems, today i am going to have to call an engineer being as i am not one. probably the best thing to do!!
Cheers andy
