Quite a substantial amount of water is remaining below the rubber as shown in photo.
I tried to check if the three holes were blocked - they are not. Filter cleaned. All seems fine.
Any suggestions?
post-3046-0-45955300-1412195534_thumb.jp
It looks like it may just be a badly designed seal unless it's not been fitted properly. There are often a few small drain holes in the bottom of a door seal which should be right at the bottom in the centre. Is this something that's just started to happen when it never did before?
