nev93 Posted July 7, 2012 Posted July 7, 2012 Hi this is my first post so be gentle with me lol.My indesit has all of a sudden started to make a sound like a jack hammer when on full spin.After looking a various posts etc i think it might be the bearings but i dont know.It would appear the drum has more movement front to back than normal. Ive checked the bushes for the shocks and they seem fine. Can any one give me any advice please? Cars i can do but am stuck when it comes to washing machines lolalso is it any easy fix?many thanks
Root Admin Whitegoodshelp Posted July 7, 2012 Root Admin Posted July 7, 2012 Noises are difficult to help on without hearing them but I have a comprehensive guide to troubleshooting noisy washing machines Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
nev93 Posted July 7, 2012 Author Posted July 7, 2012 Hi thanks for that. the drums turns ok but there is a slight grinding noise when turned by hand when empty. my main concern is the front to back movement. i can move the drum all the way forward and backwards about 2 imches each way. Is this a sign the bearings have gone? i feel quite happy changing them im just looking to confirm it if i can before i strip it down lol. Thanks again
Root Admin Whitegoodshelp Posted July 7, 2012 Root Admin Posted July 7, 2012 The main outer drum is on suspension and springs, so it should move back and forth and side to side but the inner drum shouldn't move front to back even a few millimetres because the drum pulley is fixed at the end. If drum bearings fail or collapse the tell tale movement is up and down. You need to take off the belt and spin the drum to make sure the noise you hear is coming from the drum and not the motor. When drum bearings fail they should cause a rumbling noise. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
nev93 Posted July 7, 2012 Author Posted July 7, 2012 Ok ive taken the back off the machine and it may be the struts. they dont apear to have any inserts in them. is this normal or have they failed?the hearing looks and sounds ok when i take the belt off. does this sound like i need to replace the shocks as everything else looks ok?
Root Admin Whitegoodshelp Posted July 7, 2012 Root Admin Posted July 7, 2012 Unfortunately only someone present to hear and observe the machine could try to guess what is causing the noise. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
nev93 Posted July 7, 2012 Author Posted July 7, 2012 The noise is only when om full spin. but the bears are fine. the shocks dont look loke they have any inserts so dont look like they are holding the weight of the drum. the springs are holding up the drum. do these shocks have inserts if so i will need to replace mime. Thanks again
Root Admin Whitegoodshelp Posted July 7, 2012 Root Admin Posted July 7, 2012 Unplug the machine, take the top and back off and bounce the tub up and down and from side to side to see if you can replicate the noise and where it's coming from. The tub should bounce up and down on the suspension. Most washing machine suspension is very cheap and crude these days. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
fruittool Posted September 8, 2012 Posted September 8, 2012 Hi, i have a widl126 that started making a racket while spinning, a real hard banging sound. At first i could not locate the problem but then just by luck i decided to push upwards through the rear access on the rear weight block and it shifted very slightly. Took out the bolt, got a small tube of threadlock or threadseal from the car accessories shop, stuck the bolt back in. It took about two years to loosten the bolt now it's done another three without loostening again. Whitegoodshelp 1
