Showing results for tags 'stops during cycle'.
  1. HI I have a bosch avantixx approx 5 years old and it keeps stopping during the cycle flashing up the F17 Error It first stops about 10 minutes into the cycle with the F17, it seems to keep draining long after the water has gone The F17 Error flashes up at least 2 more times throughout the cycle so I have to press the start button to continue, this happens about 3 times and then it finishes, I have checked that following: Hose is not kinked Filter has been washed Filter on the inlet is clear Blew down the pipe from the pressure switch, that's clear Checked the large piece of plastic that the pressure switch pipe goes to, that's clear Using a temporary machine at the moment and that works fine in it's place so not a drainage pipe issue or pressure problem I bought a pressure switch from bosch to see if that was the problem but they sent me the wrong one so have had to return it Any help will be most gratefully received
