Showing results for tags 'pressure switch lg'.
  1. I'm a newbie so please be gentle... Help me please - I'm going loopy!!! My LG F1480YD5 washer dryer is tripping the RCD on my house consumer unit due to water travelling up the pressure tube and spraying on the power filter pcb during the spin cycle. So far, I have (here we go...): Replaced the power filter pcb, replaced the pressure switch, replaced both impeller pumps, removed and cleaned out the rubber boot between the pumps and filter, removed and cleaned the filter, removed and cleaned the drain pipe and I have cleaned out the outlet pipe in my kitchen with is only for the washer dryer. When the RCD trips, I remove the top cover from the washer dryer, remove the power filter pcb and dry it and the associated connectors with a hairdryer for a few minutes, put it all back together again and hey presto, it works! Can anyone shed any light on this for me please? Finally I would like to say all help will be greatly appreciated. Cheers
