Showing results for tags 'john lewis'.
  1. Hi, I have had the engineers out several times on my 3 year old John Lewis (AEG). It is now fixed after replacing the drum and the motor and fixing a loose wire on the heater. However the front seal clip fell off today on the first load after the fix. It is not tight as the spring has been stretched. I have squeezed the spring so it is a bit tighter and probably won’t fall off again, but it’s not really serving any function. Is this a problem or should I just leave it? Also the arrows at the top of the seal don’t line up. The seal is about 1 cm to the right. Are either of these things something I should worry about. Many thanks, James
