Showing results for tags 'drying problems'.
  1. Beko washer/dryer WDR 7543121W product code 7161541500 does not dry. The element that fits in the bottom of the drum has been replaced but this only heats the water during the wash cycle. Is there another element for the drying cycle? If so, where is it located on the machine? Or could there be another cause? Any help you are able to give will be gratefully appreciated.
