Hi all,
Thanks for letting me join these forums! I am after some help sourcing a part for my washing machine.
We recently found out that the reason for our CMD146 Smart Washer Dryer has largely stopped working is because of a chaffed flat ribbon cable (about 1 metre long). This cable runs from the module which is situation bottom rear of the machine and runs tightly with other cables to the top rear via cable tidies to the front control board and so needs to be around a metre in length.
After looking into this and speaking to several suppliers. Each time I've been told they cannot tell me the size of the cable or the cable is around 0.3m long.
I later took the plunge of a part from partmaster.co.uk (unknown size but assured it was the right part) and on arrvial I was disappointed to find it was around 30cm long.
I've spoken with Candy genunine parts and they instantly assumed I needed the harness set of cables but its definately not the case. At the moment I have sent them the same pictures as below.
I've attached pictures of the said cable including the incorrect supplied.
In terms of written information on the damaged cable - it is as follows - E111235 AV AWM Style 2651 300v 105oC VW-1 LL89862 CSA AWM I A/B 300V 105oC FT1
Any help would be greatly appreciated and in all honesty, if someone was able to help supply the part I would happily pay over the odds for it!
Hello. Unfortunately this kind of part is very hard to source as it's not commonly used. I can find some possible candidates on 4washerhelp spare parts but there are no photos and no size description so you can't be sure. I would suggest sending in a spare part enquiry to 4washerhelp spares, which is run by the same company that runs the official Candy spares sites and has the same prices and database. Send as much relevant information as you can and they should be able to look it up on a spare parts diagram and identify it for you.
