Hi
I have a Bosch washing machine (WAS68460GB) that won't power on and am wondering if there's a simple way to make it work.
A technician from the gas company had to move the machine to get to the meter yesterday and since then it won't turn on. The dial doesn't do anything and the power button doesn't work.
I've tested the plug socket and it works, and tried the machine in a different plug and finally replaced the fuse on the machine's plug.
Any advise or help would be greatly appreciated.
Sean
  • 4 weeks later...
Unfortunately you've checked the main things for a dead washing machine. Without a continuity test meter there's not much else you can do as the fault needs tracing electrically with a meter. There's some rudimentary advice here including naming possible suspects - Washing machine is dead, wont start
