Hiya, I have had my machine for 3 1/2 years, we moved it slightly the other day to install dishwasher but now the 1st 3 lights are flashing which apparentky means 'electronic card has failed', now my question is can I sort this myself or if I do call an engineer will it be worth sorting os should I just buy a new one for £180? Thanks
If the fault only occurred after moving make sure the taps and water supply are ok and make sure the socket is good and supplying full power. It's a bit of a coincidence if it was working ok before. Otherwise I wouldn't buy a board, they are expensive and it may not fix the fault.
HI just a throught but if the dish washer and machine are side by side then there will be a drop in pressure as one item will be more stronger,For example if the d/w and the W) machine are on at the same time and you try to use the shower there will be a massive pressure drop on the water supply.The shower then cuts out lights flashing saying low pressure see what im driving at.
