Hi everyone,
I have a hotpoint WF640, which every time its used its pouring loads of water out of soap draw and im getting a gurgling sound coming from dispenser to tub hose!!!
I've made sure all filters and hoses are clear... ive even strip the whole machine down trying to find the fault.
I've fitted a new pressure switch with seems for now cured the water pouring everywhere? Fingers crossed....!
However im still getting the gurgling sound?
Does anyone know what this could be?
It's not unusual to get a gurgling sound when filling depending on the water pressure and design. Ensure there isn't anything partially blocking the bottom of the dispenser where the water runs into the tub or stuck inside the dispenser to tub hose from the bottom of the dispenser. Also make sure the machine is level and maybe try turning the water pressure down a little if none of those bring results.
I have an article which covers all the causes of Water leaking from dispenser drawer
  • 2 months later...
Hi now this may sound a little stupid but could the GLUG SOUND be the water going into the sink connector / water dranage when the pump drains the water from the machine.
