zanussi71 Posted November 27, 2011 Posted November 27, 2011 my Zanussi TurboDry 1000 does not spin properly.i have checked the brushes and they look ok, so now i am trying to figure out whether the motor is also ok. i am trying to do a continuity test as described here:http://www.washerhelp.co.uk/forums/topic/67-hotpoint-wm31-spin-failure/page__p__237__hl__%2Bcontinuity+%2Bpins__fromsearch__1#entry237Zanussi washing machine: Model TurboDry W 1042 WMotor: MCA 38/64-148/ZN208 Pin connectorPin 1 : BrownPin 2 : Blue (brush 1)Pin 3 : Light brown (brush 2)Pin 4 : GreyPin 5 : GreyPin 6 : BlackPin 7 & 8 : Red (these are thinner and seems like it is the tacho coil)There is continuity between Pin 1 and Pin 6, i get a reading of 02.5There is continuity between Pin 2 and Pin 3, i get a reading of 04.3There is continuity between Pin 4 and Pin 5, i get a reading of 00.7How do i know if the motor is ok from these readings ?thanks very much
Root Admin Whitegoodshelp Posted November 28, 2011 Root Admin Posted November 28, 2011 If the brushes are not worn right down, and are nice and shiny plus you get a reading between them through the appropriate pins they should be ok. If you get continuity between the other pins then it implies the motor should run or at least attempt to run. If it doesn't then other problems such as connection issues on the motor plugs could be to blame. Also the control module may be faulty. I never advise anyone to speculatively replace control modules or pcbs though. You get no possibility of returning them, they can be expensive, and are the most misdiagnosed parts on washing machines.If you've eliminated anything obvious I would advise getting an engineer in rather than speculatively swapping parts. General help for washing machine which won't spin Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
