johnchadbourne Posted July 3, 2011 Posted July 3, 2011 The above stops, won't drain or spin automatically. Lights flash 14 times. Can operate it manually to drain/spin. Have cleaned out pump filter (which needed doing).
Root Admin Whitegoodshelp Posted July 7, 2011 Root Admin Posted July 7, 2011 The only Candy error codes I have for Candy that go up to 14 are for the Candy Grando Series where error 14 is listed as meaning - "Missing Water Heating: defective NTC probe and/or defective water heating element and/or wiring". If this error applies to your washing machine it seems the heater isn't working for some reason hinted at in the description. The NTC is the thermostat usually pushed inside a tube of the heater or placed in the outer tub close to the heater. It should have two wires on it. It is filled with temperature sensitive crystals which change their electrical resistance at different temperatures. They normally have a high resistance reading at room temperatures and are not easily tested without knowing the exact resistance measurements. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
Root Admin Whitegoodshelp Posted October 31, 2013 Root Admin Posted October 31, 2013 These articles may help - Washer stops with lights flashing Not heating water Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
