fubarredbeko Posted June 21, 2025 Posted June 21, 2025 (edited) OK so this is a weird one. I've watched lots of videos explaining how to replace brushes on a Beko machine and none of them featured thick plastic being pulled out the motor or being stuck to brushes. So I'm thinking it's protective plastic covering the commutator that should have been removed during manufacturing? It was causing a grinding noise. It was not originally tripping the power. It's only doing that since removing the plastic. Pics included. Anyway, although there's no more bits being released onto the floor under the machine and I've removed most if not all the plastic and the machine doesnt make any grinding noises anymore the machine still trips the power when its in spin cycle. Any ideas?! Model number is BEKO WTG620M1W TiA! Solution: Plastic sheath around commutator should have been removed when manufactured. Removed motor and opened the two steel chassis sections to reveal severely damaged commutator with deep gouges, see photo. Replacement motor bought Part required: Arcelik 2842510100 motor Edited June 21, 2025 by fubarredbeko Added extra info and solution Whitegoodshelp 1
Root Admin Whitegoodshelp Posted June 23, 2025 Root Admin Posted June 23, 2025 Wow. Never heard of that. I can't understand how it ever ran properly in the first place. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
