foxykiwi Posted September 4 Report Share Posted September 4 Hello, I have a John Lewis 1417 machine that started to make a strange noise and then the drum stopped. The machine still 'works' in that I can select a programme it can fill and empty etc, it's just that when it gets to the bit where it actually needs to rotate to wash, it just doesn't. The drum is rotating if I push it round and it I have done some research and think perhaps it is the carbon brushes. I have taken the back off, remove the electrics and the 2 front motor bolts but cannot move the motor at all. All the videos I have watched seem to show a little pull and the motor is removed so I must be missing something! The machine isn't that old, can't be more than 5 years. Can anyone help? From what I've read the motor should pull out by removing the front 2 bolts but it's just stuck and I'm wondering if there's something else I need to do. I have tried to lever it with a screw driver but am getting nowhere. I would be really grateful for any help/ideas about what it might be. Thanks in advance Foxy Link to comment Share on other sites More sharing options...
foxykiwi Posted September 4 Author Report Share Posted September 4 Just replying to myself 🙂 I realised that there are 4 bolts and have now removed the back two (with great difficulty!) and have managed to remove the motor. The carbon brushes are indeed very worn so I am ordering them tonight and will update when I've fitted them. Whitegoodshelp (Andy) 1 Link to comment Share on other sites More sharing options...
Root Admin Whitegoodshelp (Andy) Posted September 5 Root Admin Report Share Posted September 5 Thanks for the update. Hopefully you've removed the brushes and had a look at them before ordering new ones? If they need replacing it should be obvious just by looking at them. This article describes what to look for when checking if you need to fit new carbon brushes on a washing machine Need a repair or spare parts? Book a Repair | Buy appliance spares (Cheapest prices guaranteed) Warning: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith. Link to comment Share on other sites More sharing options...
foxykiwi Posted September 7 Author Report Share Posted September 7 Thanks Andy for your reply. Just an update in the hope this thread helps someone else. Fitted new carbon brushes, I went for a generic part so it was cheap and if it didn't work I hadn't spent much (only cost £12). I'm pleased to say that the machine is now working again. Obviously not sure how long it will last but it's working! Link to comment Share on other sites More sharing options...
Root Admin Whitegoodshelp (Andy) Posted September 7 Root Admin Report Share Posted September 7 Thanks for the update. That's good. If the washing machine is relatively old that's fine, but unless something has changed that I'm aware of, non-genuine carbon brushes tend to wear out fast, and cause a big build up of carbon dust. They tend to be very much softer and less compact than genuine carbon brushes. This can shorten the life of a motor drastically. If used heavily, I'd consider getting genuine brushes now you know what the issue was. Need a repair or spare parts? Book a Repair | Buy appliance spares (Cheapest prices guaranteed) Warning: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith. Link to comment Share on other sites More sharing options...
