jakeb Posted September 30, 2022 Posted September 30, 2022 Hi all. I just did a wash on a 40 and towards the end my drum started screeching and spinning very slowly. When the wash finished all I could smell was burnt rubber?! Any suggestions VID_20220930_143752473.mp4
Root Admin Whitegoodshelp Posted October 2, 2022 Root Admin Posted October 2, 2022 Wow, that noise went right through me Is the drum catching on the back of the door seal? Carefully check the drum for damage, and lift it towards you and up. Does it move up and down? If so, the drum spider may have cracked or the drum bearing collapsed. If not, turn the drum all the way around a full revolution whilst lifting and pulling towards you to see if there is movement, maybe just at one spot. That would indicate a cracked or broken drum spider (there are 3). If you can't detect anything, you'd need to take off the drum belt and then turn the drum to see if the noise is definitely coming from the drum, and not the motor. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
