Faghan Posted September 6, 2022 Posted September 6, 2022 My washing machine made a weird noise and then stop spinning after investigation and completely cleaning the drain hoses, I learned that the lack of spinning if because the drum is seized up. The motor works fine, the bearings look ok, the drain function works fine… the only explanation I found online is that something is stuck between the inner and outer drum.. but the drum doesn’t move even one bit.. is that the only explanation? Should I see dents if that’s the case?
Faghan Posted September 6, 2022 Author Posted September 6, 2022 68416030852__1DB890B2-B436-4E9E-8B7A-3D7BEDE5FC72.MOV
Root Admin Whitegoodshelp Posted September 6, 2022 Root Admin Posted September 6, 2022 Hi. It seems to move a fraction. When it stops does it feel like whatever is blocking it is solid like metal or with slight give like say a sock or pair of pants? The latter is main suspect of it hasn't been noisy and bearings seem OK. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
Faghan Posted September 6, 2022 Author Posted September 6, 2022 1 hour ago, Whitegoodshelp (Andy) said: Hi. It seems to move a fraction. When it stops does it feel like whatever is blocking it is solid like metal or with slight give like say a sock or pair of pants? The latter is main suspect of it hasn't been noisy and bearings seem OK. Pretty sure it’s the latter. Can I fix it without having to open the whole thing?
Root Admin Whitegoodshelp Posted September 6, 2022 Root Admin Posted September 6, 2022 It depends where the obstruction is. If its somehow wrapped around the drum shaft, or got round the back and between the back of the inner drum and the outer drum it would need stripping down. And many modern washing machines are designed in such a way that they can't be stripped down (sealed drums). If it's something trapped underneath the drum it may be possible to retrieve it. I have some advice and help here How to remove something stuck under drum Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
