Dazie Posted November 28, 2021 Posted November 28, 2021 (edited) Hi all, ZANUSSI ZWF1430W My w/c had a small leak and when I removed the top cover I found that the small top vent hose was the source. That has now been fixed by replacing the hose. However, in the process I observed the drum and noticed it moving around a lot. The problem is that I don't have experience of doing this on another w/c so no idea if this movement is within normal range or it is excessive. This link shows the w/c doing its wash cycle: https://youtu.be/uJLYt8HD-Vc This link shows the w/c draining and ramping up for its spin cycle: https://youtu.be/l-gp--lpdXk Does anyone have a comparison to know whether this is normal or not. If not normal then I presume I am looking at replacing the two shock absorbers at the bottom? Edited November 28, 2021 by Dazie Correction to video links
Root Admin Whitegoodshelp Posted November 29, 2021 Root Admin Posted November 29, 2021 Hello Dazie. Yes everything looks perfectly normal there. The drum is held in place with springs and is supported on suspension dampers so it is totally designed to move around and absorb movement. The amount of movement will vary depending upon the load inside. If you have an uneven load inside then the tub can sway around quite a lot and potentially even thump against the sides. You may find my article on how to load a washing machine of interest as it describes the best way to get a nice even load and how to avoid getting an uneven load which can in extreme cases damage the washing machine The best way to load a washing machine Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
Dazie Posted November 29, 2021 Author Posted November 29, 2021 Thanks for your input @Whitegoodshelp (Andy). I realised it should move a little on those springs and shocks, but I just thought it was quite a lot of stress being added to that top vent (which may have made it fail) and the door seal. But if you think it is normal I will leave alone for now. Whitegoodshelp 1
Root Admin Whitegoodshelp Posted November 29, 2021 Root Admin Posted November 29, 2021 The best way to reduce movement and therefore stress on the hose is to put good balanced loads in 😁 Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
Dazie Posted November 30, 2021 Author Posted November 30, 2021 Yes, thanks again. I read your article and now understand why occasionally the m/c does not run its fast spin! Whitegoodshelp 1
