Hi Forum
Got a Miele WKG 130 - NDS with TwinDos, however when I try to run the TwinDos maintenance it only works on container 2 - with a TwinDosCare container - when the TwinDosCare is in container 1 - I receive a display message that "there's not enough detergent/water in the container. Repeat process"  - tried 6 times now and the same occurs
1) Has anyone seen this "problem" before and knows how to solve it?
2) Does anyone knows how to "force" the use of container 2 on every wash?
Thanks in advance  1
Apart from cleaning out the containers there's not much else to do. There has to be some device that detects the levels and if everything is clean and in its proper place it's likely to be a fault on the devices for checking the levels.
