tom90 Posted October 11, 2020 Posted October 11, 2020 Hello, I have a Hoover HBWD 8514TAHC washer dryer which has been stuck before the final spin for some time today. I've noticed a noise coming from it which I hadn't heard before. Having taken off the back panel to listen more closely, it seems to be coming from the motor, and it does it when I manually move the drum whilst the machine is switched off too. Can anybody advise on what the sound is, and whether or not this is repairable? Here's a video on Dropbox: https://www.dropbox.com/s/iqa8irsfl95lezx/VID_20201011_140535.mp4?dl=0 Thanks, Tom
Root Admin Whitegoodshelp Posted October 12, 2020 Root Admin Posted October 12, 2020 Hello Tom. It's difficult to hear anything drastically wrong there although I can hear a strange noise high-pitched noise every so often. The main thing I noticed is that the drum and motor seem to be running quite unevenly. Was there a small load of laundry in when you took the video? It looked as if there was an unbalanced load in there, which can stop it from going into a fast spin. It might be better to try running it again without any laundry in at all. tom90 1 Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
tom90 Posted October 13, 2020 Author Posted October 13, 2020 Thanks Andy, I put a small load in in the hope that would test if it works with less in, but it was a rather heavy wet towel, which I'm guessing wouldn't spread round to balance it out. I've tried with other loads and it seems to work now. The noise is still there, the high pitched "ts" noise every second or two, but I'll see how it goes. Thank you for your help! Tom
