Grahams Posted May 5, 2020 Posted May 5, 2020 I have hotpoint washer/Dryer it has a hell of a noise you can’t here yourself speak l i have replaced a broken concrete block,Both shock absorbers the bearing are perfect any ideas please thanks for reading
Root Admin Whitegoodshelp Posted May 6, 2020 Root Admin Posted May 6, 2020 Hello Grahams. It looks like you've covered most of the main causes of noisy washing machines - especially a very loud noise. Unfortunately I can't guess at anything because you haven't described the noise (although it's difficult to describe noises accurately). The only thing I can suggest is to painstakingly go through all of the possible causes in my two articles on the subject staring here - Washing Machine is noisy Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
Grahams Posted May 6, 2020 Author Posted May 6, 2020 Hi Andy i have read them so I am going to check some out my model number AQM8d69I IF IT IS THE bearings can they be replaced
Root Admin Whitegoodshelp Posted May 6, 2020 Root Admin Posted May 6, 2020 Hello. If it's drum bearings it should be obvious if you spin the drum by hand with the belt taken off. It should rumble. I would advise against trying to replace drum bearings. Too big a job, too many potential complications such as finding drum shaft or spider damaged and bearings seized in drum and won't come out - plus most modern washing machines only have complete drums available with bearings already fitted at great expense. You'd have to put your model into a spares site to see if they are available. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
