Hi guys, sure hope you can help me on this one! With the virus situation we're stuck at home and my wife is loosing it ...:unsure:
Well, after completing a cycle and reloaded, my noticed that the machine is not responding.
  • Display is showing blinking "Play"sign (pause/play) and most of the other info is not showing
  • Program selector is not responsive either (nothing changes)
  • Unplugging for 20 Min did nothing
  • Found out on the net a procedure to turn it on while the program selector is at "12"and while holding the "Play/Pause"button and it turned on showing F 08. Also when pressing the "play/pause" at this stage shows C88 (Can be seen in attached video)
  • BTW I once knew a key combination to hold for a few seconds to reset the controller but I forgot it... does anyone know it?
I'm attaching videos of the display in normal Ön" and with the F-08 as I described above.
Any help on this would be very much appreciated!!!
Thanks and wish us all good health!
Dedy
Edited by Dedy
misspell
Unfortunately I don't have any error codes for Blomberg. What's that high pitched noise, is that the washing machine and normal?
Hi Andy,
Thank you for your reply.
I have managed to solve this!
Just went over the most suspicious things, it was the door switch /locker
By the way, to reset the code after the replacement, you need to hold the two buttons below the display, marked with a lock symbol...
Best,
Dedy.
