Chris79 Posted January 6, 2020 Posted January 6, 2020 Afternoon all. Have a neff washing machine that has been playing up lately. On Christmas Eve it stopped spinning, washing and all we got was a hum. Checked the drivebelt and brushes and decided brushes needed to be changed. After installing new brushes all worked fine for a few days but for some reason isn't spinning now. Washing cycle is fine but for some reason doesn't want to spin on some cycles. The washer drains fine also. Anyone any ideas as it's quite old I believe and don't want to keep throwing money at it.
Root Admin Whitegoodshelp Posted January 7, 2020 Root Admin Posted January 7, 2020 Hello Chris. Humming isn't usually associated with worn carbon brushes. If brushes are worn they either stop making a connection, or they make a very poor connection. In the fist scenario the motor is totally dead, and in the second the motor will turn but erratically, or it will be lethargic and uneven and they is usually a crackling or grating noise caused by sparking between the brush and the commutator. A humming noise is usually more associated with an induction motor (that has no brushes) or with an electrical fault causing the motor to not receive anywhere near enough power to run but just enough to make it try. Having said that I would check the brushes again, are they smooth where they contact the commutator or is there any charring indicating poor contact? Also check all the connections and pins in the motor and motor plug. If nothing is found it could be a fault on the windings on the motr, or the armature or the pcb. Also double check that the drive belt isn't loose and the motor isn't slipping inside the belt. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
Chris79 Posted January 8, 2020 Author Posted January 8, 2020 (edited) On 07/01/2020 at 11:22, Whitegoodshelp (Andy) said: Hello Chris. Humming isn't usually associated with worn carbon brushes. If brushes are worn they either stop making a connection, or they make a very poor connection. In the fist scenario the motor is totally dead, and in the second the motor will turn but erratically, or it will be lethargic and uneven and they is usually a crackling or grating noise caused by sparking between the brush and the commutator. A humming noise is usually more associated with an induction motor (that has no brushes) or with an electrical fault causing the motor to not receive anywhere near enough power to run but just enough to make it try. Having said that I would check the brushes again, are they smooth where they contact the commutator or is there any charring indicating poor contact? Also check all the connections and pins in the motor and motor plug. If nothing is found it could be a fault on the windings on the motr, or the armature or the pcb. Also double check that the drive belt isn't loose and the motor isn't slipping inside the belt. Thanks for the reply. Completely stopped doing anything and just got a humming sound from the pump. Took the motor out, fiddled with the brushes again and started working again. The washing machine seems to drain fine but does make a humming sound when spinning from the pump. Don't think the pump is the issue as I would have thought it wouldn't drain properly? Edited January 8, 2020 by Chris79
Root Admin Whitegoodshelp Posted January 8, 2020 Root Admin Posted January 8, 2020 Right. The humming may just be the sound of the pump running, which appears louder if the motor and drum have stopped turning. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
