Chris England Posted March 13, 2019 Posted March 13, 2019 Hi, sorry for the long backstory, thought it would be best to add the full information. I have an Indesit xwd71452 xkuk My other half recently overfilled our washer and a sock managed to somehow bypass the drum seal and wedge itself between the drum and the water inlet pipe. Chaos ensued as the water backed up rapidly and started to pour out of the powder drawer. Once i had removed the offending item and started a new wash a h20 error occured about a minute into the cycle. The pre-wash was filling correctly but no water was entering for the main wash, apart comes the machine again and on checking the inlet valve solenoid was showing an open circuit. I have now replaced this but the washer isnt sending a signal to the new valve to open. Ive taken apart the main control board housing and it appears that the triac for the fill valve signal wire is blown. All other components seem to be functioning as intended. Indesit say its not possible to repair the board and it would need to be reprogrammed, my question is do you expect that will be the case or will a replacement triac sort the job as its no where near the micro chips themselves. Any help or guidance would be appreciated.
Root Admin Whitegoodshelp Posted March 14, 2019 Root Admin Posted March 14, 2019 Hello there. It seems very strange that the fault would occur after the sock incident, unless water somehow leaked out onto electrical parts. Washing machine repair engineers don't repair pcbs. Manufacturers have never facilitated repairing them. So I have no idea about the components inside pcbs other than general knowledge about resistors etc. The only repairs I've ever done to them are soldiering dry joints. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
Chris England Posted March 16, 2019 Author Posted March 16, 2019 Hi Andy and thanks for the response. I traced the cables back to the circuit board from the valves and worked my way back from there. They are controlled by a bank of Triac's and MOV's triggered from the main microcontroller. One of the triacs had gone bad, i isolated this just using a basic diode check function on a multimeter which indicated that there was no voltage drop across the component. Replaced with a new triac (Z0107NA if anyone is interested) and all is well again! Its not something i would recommend unless you have experience with soldering electronics as these components are heat sensitive and easily damaged whilst fitting. Ive tested on each cycle now and none of the programming seems to have been affected either. Thanks for the quick response anyway and have a nice day! Whitegoodshelp 1
Root Admin Whitegoodshelp Posted March 18, 2019 Root Admin Posted March 18, 2019 Many thanks for the update. Well played. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
boris Posted July 21, 2023 Posted July 21, 2023 Hi there ! I have a similar issue, but I think with a different component, i.e. : Do you by any chance know if this triac is also a Z0107NA ? Unfortunately the label can't be seen on my board... Thank you in advance.
paul james Posted June 20, 2025 Posted June 20, 2025 Hi Boris , I was interested in your question , as i have the same issue with a blown transistor in the same place on my PCB. The code etched on this PCB alongside the transistor looks like Q018 , and your one appears the same. Of course , the code on the transistor itself, (having blown ), is unreadable . The door lock mechanism is haywire on this machine. Did you ever find out the answer to your question about the triac ? Did you solve the issue? Thanks in advance Paul
