newbuilder Posted January 24, 2019 Posted January 24, 2019 Hi, first time poster and problem solver. The machine in question managed to tangle up the bedsheets resulting in an unbalanced load. The OH let the load continue and as a result the machine bounced out of the space and turned 90 degrees. It also burst the door seal and caused a scrape in the glass. I didn't see it but it must have sounded like an earthquake. Since then the machine has an excessive vibration during the spin. The machine is level and does not move when spinning, the drum shakes from side to side but on rotating it by hand their is no bearing grind or thump and whant moving it forward and backwards their is no gapping between the seal and the drum. I haven't yet checked the bolts holding the concrete weight but have ordered a new seal and will do this at the time. When in full spin the vibration can be felt in the floor in the next room. Is there anything else this could be? Springs, dampers etc? and what should I be looking out for whilst I have the top open to get to the seal? Many thanks.
Root Admin Whitegoodshelp Posted January 28, 2019 Root Admin Posted January 28, 2019 Hello there. I would suspect problems with suspension dampers you need to take up the back panel and have a good look inside to see if anything is obvious. Washing machine suspension dampers these days are often pretty cheap plastic things. One might have broken or come loose. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
newbuilder Posted January 28, 2019 Author Posted January 28, 2019 Hi Andy Thanks for the feedback. I have had a good look and there is no visible cracks or failing parts but on grasping each piston I can wobble the outer sleeve from left to right a little. Could this be wear and tear? A few videos https://drive.google.com/open?id=1LhMmh1LPQt13AYGzz_z_96zrvGhYowJk (326MB) https://drive.google.com/open?id=1dE-u1ppgi53ORBltc40gLSwo6zbdTN9N (79MB)
Root Admin Whitegoodshelp Posted January 29, 2019 Root Admin Posted January 29, 2019 Hello there. I can only access the second link. If that washing machine has a load of laundry inside the drum it doesn't seem abnormal to me at all. On the other hand if there is no laundry inside the drum then it is excessively vibrating. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
Root Admin Whitegoodshelp Posted January 29, 2019 Root Admin Posted January 29, 2019 The machine sounded normal for 3 towels in it. 3 towels are likely to cause more vibration than 7 or 8 because 3 isn’t enough so it would be unlikely to get balanced well. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
