I am at wits end here folks. I don't know what to do about this washer i had to replace the back support spindle and finally got that done put the drum back together and the heating element was touching the drum reset that to where it ran through its little bracket and still the machine through the t3 code. I then replaced the thurmistor and still it throws the t3 code after waiting about 20 seconds. I don't know what else to do as all the code references from google searches say to replace the thermistor. I did and i  know that bad parts come through but i would hope for $40 it wouldn't had been a bad part! PLEASE HELP ME i don't know what else to do! I can give you the model # if it helps also it is an american vs. of the machine!
If an error code implicates a thermistor but replacing it doesn't make any difference you need to carefully check the connections and wires to it. If possible verify continuity from each of the connections down to the pcb. It's always possible there's a fault in the pcb but don't change it because there's no guarantee it will make a difference. If the error code only happened after carrying out repairs double check all wires and connections.
