neessen88 Posted December 25, 2018 Posted December 25, 2018 I have a Samsung WF70F5E5P4W which is about 3 years old, and two days ago it starte acting strange. It starts the program, the drum spins okay, but then at some point in the program it seems stuck. It tries to rotate the drum, but it only moves a couple of inches, and then goes back, then it tries it in the other direction. eventually the washer stops (pause). I can then resume it, but most of the times it does the same thing again and stops, Sometimes it continues th program, but might again stop at a later time. I have been able to manually rotate the drum at all times, so it is unlikely that it is stuck against something. I have checked the wirering at the back, but nothing seemed to be broken or disconnected. I got an 3E error once, but only that one time. I have recorded a video of the behavior here. Do you have an idea of what might be causing this? Any help would be appreciated :)
Root Admin Whitegoodshelp Posted January 2, 2019 Root Admin Posted January 2, 2019 It looks like a fault either on the motor or the PCB or capacitor etc. It's not something to tackle yourself as it would involve potentially gambling on replacing expensive parts that may not fix the fault. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
neessen88 Posted January 7, 2019 Author Posted January 7, 2019 Okay - thank you for your answer Whitegoodshelp 1
