DanaScully Posted November 5, 2018 Posted November 5, 2018 Hello I have had a look through the troubleshooting guide, but I've not been able to pinpoint exactly what the issue with my w/m is. I think it might be the carbon brushes, but I would really appreciate your input. I bought a secondhand 6kg Indesit washing machine (IWC6105) almost three years ago which has been running fine until recently. When spinning, the machine would make a quiet clicking/ticking type of noise which I didn't pay much attention to as the machine was still functioning fine. Cut to last night, the machine started making a much louder noise and suddenly stopping mid programme and resetting itself. When I tried to drain the machine, the light glows but nothing happens except some quiet clicking inside the machine. The spin cycle seems to be where it's stopping and resetting itself. If I empty the machine and try to spin, it will spin for a short while but not very fast and then cut out. Yesterday I initiated a single rinse cycle and recorded some footage. When the spin started it quickly cut out and reset. All of the lights on the panel flash and then the start/pause light flashes intermittently as if the cycle has been manually paused. Today the machine will not spin at all and just makes various clicking and ticking noises. Here is a link to the footage. I would greatly appreciate any advice as to what this issue could be and also whether it's worth me trying to repair it or if it's a bigger issue than the machine is worth. I regularly check and clean the filter and have done so over the weekend, so I don't think this is filter related. Thank you! https://youtu.be/Gxsm_Cca3Do
Root Admin Whitegoodshelp Posted November 5, 2018 Root Admin Posted November 5, 2018 Hello there. That sounds terrible. It doesn't sound like carbon brushes at all. It sounds like either the motor is really badly worn, or there is some nasty metal to metal scraping going on. When trying to find out what is causing a horrible noise on a washing machine it really is extremely simple. You don't need to be an engineer at all. You just have to use your eyes and ears to locate where the noises coming from. You need to disconnect the washing machine from the mains and try to make the noise happen yourself in case it is something extremely obvious. For example, the washing machine motor may be catching on the back panel or chassis due to worn suspension. Spin the drum by hand, or get someone to spin it by hand whilst you are behind the washing machine with the back and the lid off. Bounce the washing machine's outer drum around by hand, moving it from side to side forward to back. If you can't see anything obvious the washing machine will need to be plugged in. You need to be extremely careful of course as this is potentially dangerous, so ensure that no one gets electrocuted or loses a finger! Full diagnostic help is on this article here Washing machine is noisy Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
DanaScully Posted November 5, 2018 Author Posted November 5, 2018 11 minutes ago, Whitegoodshelp (Andy) said: Hello there. That sounds terrible. It doesn't sound like carbon brushes at all. It sounds like either the motor is really badly worn, or there is some nasty metal to metal scraping going on. When trying to find out what is causing a horrible noise on a washing machine it really is extremely simple. You don't need to be an engineer at all. You just have to use your eyes and ears to locate where the noises coming from. You need to disconnect the washing machine from the mains and try to make the noise happen yourself in case it is something extremely obvious. For example, the washing machine motor may be catching on the back panel or chassis due to worn suspension. Spin the drum by hand, or get someone to spin it by hand whilst you are behind the washing machine with the back and the lid off. Bounce the washing machine's outer drum around by hand, moving it from side to side forward to back. If you can't see anything obvious the washing machine will need to be plugged in. You need to be extremely careful of course as this is potentially dangerous, so ensure that no one gets electrocuted or loses a finger! Full diagnostic help is on this article here Washing machine is noisy Hi Andy Thank you very much for your reply. I agree, it does sound terrible! I've been trawling YouTube for videos of different noises a washing machine might make to see if any sounded similar, but none of them really did. I did try to spin the machine with the back off to see if the noise could be sparking, but couldn't get it to spin! I'll try everything you've suggested when I'm home from work. Thanks again! Whitegoodshelp 1
