MikeN Posted July 23, 2018 Posted July 23, 2018 Recently my washing machine stopped starting, the door lock button would just flash. So after looking online I replaced the interlock mechanism which fixed the problem perfectly for a couple of weeks. But now the washing machine registers as locked and starts but the door just swings open, if I hadn't noticed it would have flooded the kitchen. I assumed the replacement interlock of dodgy so I replaced it again but to no avail. Any suggestions would be greatly appreciated. Thank you.
Root Admin Whitegoodshelp Posted July 23, 2018 Root Admin Posted July 23, 2018 The door shouldn’t be able to come open even if the door lock wasn’t locking. The door lock only prevents someone from opening the door. If the door comes open on its own it can’t be closing properly and latching properly or the door lock isn’t fitted correctly. Check the latch on the door. It should have a spring on it holding it in position. Try spraying the latch and door lock with WD40. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
