Teds01 Posted July 5, 2018 Posted July 5, 2018 Hi. Would be very grateful for advice on following problem with our integrated AEG washer dryer which is just over 4 years old. I’ve gone through your videos but am still not sure what is causing the noise. The machine has developed a knocking sound which you can hear when you rotate the drum by hand - it creates a single or double knock for each whole revolution of the drum. It’s louder when you turn the drum anti-clockwise. It is muffled during the wash cycle but then becomes very loud during the spin cycle. There is no rumbling sound and there’s no leakage or brown staining in machine. The machine works perfectly fine and cleans and drys clothes. When moving the drum by hand the noise seems to build up to the knock sound if that makes sense? Just concerned that this could build into a more serious problem. Am a confident DIYer so am up for a challenge but if machine is failing then will replace. Have tried to post video here but too large. Many thanks.
Root Admin Whitegoodshelp Posted July 6, 2018 Root Admin Posted July 6, 2018 Hello. A knocking noise is often a loose tub weight. If so it should be easy to test by disconnecting washing machine from the mains and taking off the lid. Then move and shake the drum about by hand to see if you can make the noise and locate its source. You might also disconnect the drive belt to ensure that when turning the drum you are only turning the drum and not the motor too. Also check out my comprehensive list of possible causes of a noisy washing machine Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
Teds01 Posted July 6, 2018 Author Posted July 6, 2018 Thanks. I’ve taken off the lid and back of the machine and as you recommended moved the drum around but there’s no noise so believe weights still firmly attached. I’ve taken the drive belt off and when spin the drum the clunking noise occurs although much quieter. I’ll remove the support wheel to try and see the bearings.
Teds01 Posted July 6, 2018 Author Posted July 6, 2018 Having removed the wheel (which seemed to have a little too much play) and now spinning the drum by the spindle there’s no noise at all. On the floor of the machine and in the wheel there’s a build up of fine black dust?? Maybe a new wheel would solve issue you think?
Root Admin Whitegoodshelp Posted July 6, 2018 Root Admin Posted July 6, 2018 Possibly. If the noise is caused by the wheel it should make it when you turn the drum with it on. Is it loose on the shaft, or cracked anywhere? Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
Teds01 Posted July 6, 2018 Author Posted July 6, 2018 Yes it’s loose on the shaft. Going to replace it and hopefully that will solve issue. Will let you know. Thanks for your advice much appreciated. Whitegoodshelp 1
KateM178 Posted October 26, 2018 Posted October 26, 2018 Hi Teds01, I have just come across this thread and I am experiencing exactly the same problem. I was wondering if the new wheel solved the issue?
Teds01 Posted October 27, 2018 Author Posted October 27, 2018 Hi, yes it solved the issue. You can check by seeing if the wheel can be slightly moved while still attached. Also the fact that when I removed it there was no knocking noise coming from the drum if I rotated it by hand. The new wheel was clearly a snug fit and required a bit of effort to push it into place - this was in contrast to the old wheel that came off easily. Hope it solves your issue. Whitegoodshelp 1
Mishk Posted December 19, 2018 Posted December 19, 2018 Hi All, i have a similiar knocking noise. will any of you share the part, part number I would need to purchase to replace the wheel please? Thanks
Root Admin Whitegoodshelp Posted December 19, 2018 Root Admin Posted December 19, 2018 Hello Mishk. Have you confirmed it is the drum pulley wheel that is loose in your case? It would be risky to assume your knocking noise is caused by the same fault as other people's. It may be, but you need to check first. If it is, then the part number that other s used may not fit your washing machine. Even washing machines with the same model number could have different types of part fitted depending on when they were made. You can easily look up which part you need by selecting your brand and searching for drum pulley here - Ransom Spares Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
Root Admin Whitegoodshelp Posted February 22, 2019 Root Admin Posted February 22, 2019 I just had this fault on my son's AEG washing machine. It made a very strange knocking tapping noise when the drum turned and was quite noisy on spin but not a deep rumbling noise like drum bearings. I took off the back and the drive belt. I quickly saw that the very cheap looking and poorly made plastic drum pulley was loose on the shaft. Replaced it with new and fault cured. I videoed the noise on my phone. Will try to put it up somewhere for reference. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
Root Admin Whitegoodshelp Posted February 27, 2020 Root Admin Posted February 27, 2020 I've finally written the article which contains 4 videos. You can find it here drum making rattling tapping and grinding noise Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
