i have a Beko WMB81241 LB machine.  I recently had to install a new waste trap under my kitchen sink (which the washing machine waste pipe plugs into).
The job was done easily enough, but now my washer won’t drain!
If I pull out the waste pipe and squeeze it with my fingers, the water comes out in two strong streams, but without pinching it, it nothing comes out as I’d expect.
I would presume that plugging the waste pipe into the waste trap would allow the waste water to flow but it isn’t.
I have tried the pipe non its oennand with a jubilee clip but the same result occurs.
Does anyone have any ideas please?
Hello. New waste fittings have a bung in when new. Have you removed the bung or blanking piece from inside the spigot that the drain hose connects to?
https://www.whitegoodshelp.co.uk/washing-machine-wont-drain-after-being-moved/
