AEG lavamat 68480 FL less than 11 months old. Failed to spin properly and now won't work as unable to reset control panel which keeps displaying previous programme with time remaining left at 0.  Have cleaned filter etc at front. There was a little water but nothing of volume. Hose at rear not kinked either.  Have loaded photo of current control panel display.
Edited by gordiegem
Spelling error
Have you tried disconnecting it from the mains for a few minutes?
Is there a light that tells you if the door isn't closed? If it was on and lights are on but the machine is dead it could be caused if the door lock is faulty or has an electrical fault. If the "door open" warning isn't on then it looks like there's something wrong with communication between the PCB and control panel or a fault on the control panel - and or the PCB so it's not likely to be something you can fix yourself.
