Startex Posted January 26, 2017 Posted January 26, 2017 Have a Samsung Model WA48H7400AW. Every load I do, it just don't seem to fill enough with water. Top of clothes are exposed. Been like that since day 1. Had it about 4 months. Thanks.
Root Admin Whitegoodshelp Posted January 27, 2017 Root Admin Posted January 27, 2017 I can't know if the machine is faulty or not, but the main thing to consider is does the laundry come out clean? Many washing machines use as little water as possible these days for economy. They use a circulation pump or the drum paddles to constantly shower the laundry with water during the wash cycle. When the drum is turning can you see if water is dripping or running onto the laundry? The principle is the same as having a shower instead of a bath, it uses a lot less water and energy. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
Startex Posted January 28, 2017 Author Posted January 28, 2017 "does the laundry come out clean? " Yes ......very much so. What you talk about at the end of your post pretty much nails it. It's doing all those things. I'd have to say that everything is ok and that's just the way it's designed to work. Thanks for the explanation. Whitegoodshelp 1
