goaten2000 Posted January 16, 2017 Posted January 16, 2017 Hi There, Our washing machine over the last few months has developed a noise - it sounds like it's the pump but before I pull it apart, are you able to help diagnose this properly from the video? Many Thanks, Gareth https://youtu.be/8Gxwnnfa3ew
Root Admin Whitegoodshelp Posted January 17, 2017 Root Admin Posted January 17, 2017 It sounded like a very dry bearing on the pump but the noise stops when the drum stops rotating and it sounds like the pump is still running ok in the background? To troubleshoot this noise you would normally take off the drive belt and let the motor run separately. However, if it's one of those direct drive machines you won't be able to do that. If the noise doesn't get any louder or worse when it kicks into spin I would suspect the pump but if the noise gets a lot louder it's the motor/drum bearings. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
goaten2000 Posted January 17, 2017 Author Posted January 17, 2017 19 minutes ago, Whitegoodshelp (Andy) said: It sounded like a very dry bearing on the pump but the noise stops when the drum stops rotating and it sounds like the pump is still running ok in the background? To troubleshoot this noise you would normally take off the drive belt and let the motor run separately. However, if it's one of those direct drive machines you won't be able to do that. If the noise doesn't get any louder or worse when it kicks into spin I would suspect the pump but if the noise gets a lot louder it's the motor/drum bearings. Thanks Andy... it is indeed a direct drive machine. After a bit more digging, it looks like it could be the re-circulation nozzle being clogged up with gunk, causing the pump to make that noise. I had a go at cleaning the nozzle and it was indeed full of gunk but unfortunately water is still not getting through (it's weeping at best) so I need to get the lid off to access the hose and see if I can clean the hose. I'll report back once I've done this...
Root Admin Whitegoodshelp Posted January 17, 2017 Root Admin Posted January 17, 2017 Hello. I didn't realise it was on wash, I assumed it was on the spin cycle. Had a realised I would have said it's likely to be the circulation pump. It might need a new one. That noise sounds more like a faulty bearing than gunged up but please report back with updates. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
goaten2000 Posted October 11, 2017 Author Posted October 11, 2017 It took me a while to get round to fixing this but I bought a new pump / housing unit, replaced this and is now quiet! Thanks for your help & advice :-) Whitegoodshelp 1
Root Admin Whitegoodshelp Posted October 11, 2017 Root Admin Posted October 11, 2017 Excellent. Many thanks for the update and glad you got it sorted. Need a repair or spare parts? Book a Repair | Spares4Appliances WARNING: Read this before attempting any diy repairs. No representations or warranties are made (express or implied) as to the reliability, accuracy or completeness of advice. I can't be held liable for any loss arising directly or indirectly from the use of, or any action taken in reliance on, any information on this website, which is given free of charge and in good faith.
Frankie Corrado Posted June 9, 2018 Posted June 9, 2018 Hi Goaten 2000, it seems my machine is now displaying the same noises and problems as yours, could you advise on what and how you managed to fix yours? Many thanks My machine is not making any noises on spin so it's not a bearing and only during the wash cycle.
goaten2000 Posted June 10, 2018 Author Posted June 10, 2018 On 09/06/2018 at 18:22, Frankie Corrado said: Hi Goaten 2000, it seems my machine is now displaying the same noises and problems as yours, could you advise on what and how you managed to fix yours? Many thanks My machine is not making any noises on spin so it's not a bearing and only during the wash cycle. Hi Frankie It was the recirculation pump. These machines have 2 pumps - 1 to drain and 1 to recirculate the water. You can either replace the individual pump, or there's a unit that is the part with 2 pumps already attached (I went for this option - it worked out cheaper than a pump on it's own!) This video give you a general guide on how to access the pump, but don't bother removing the front panel with the door - it doesn't come off! (I only discovered this after removing the door seal, which turned out to be a waste of time!) https://www.youtube.com/watch?v=8cPl22OC9f4 Once you've removed the kick panel and the top panel, you'll see the pump at the bottom of the machine. Be warned it's quite fiddly with tight access, but with a bit of perseverance and patience, it can be done (and is very satisfying afterwards). Whilst the machine was apart, i took the opportunity to clean the pipes that i could access from the detergent draw, recirculation pipe etc. It's amazing how much gunk was in those pipes Whitegoodshelp 1
MegsNZUK Posted May 29, 2019 Posted May 29, 2019 Hi Goaten2000 I have also identified the same problem with the recirculation pump. We had a blockage which I have unblocked and the noise reduced however the pump still makes a significant noise on start-up so I'm guessing it was damaged under the strain. The unit you replaced (housing both pumps), was it called a Drain Pump Assembly? Thanks Megan
